Documentation for Users
2.2.2
Perception Toolbox for Virtual Reality (PTVR) Manual
Before putting your Quest headset on, here are a few steps to follow...
(image from Assembleia Legislativa do Paraná , via Wikimedia Commons).
The following steps are only given here as a small tutorial to install the Quest VR device. For more details, you can also have a look at their website if needed:
(https://www.meta.com/).
This is actually NOT necessary but you can use yours if you already own one.
Try and type 'install the Meta Horizon Link app' in your browser,
(Strangely, this app was called 'Meta Quest Link' some months ago - for instance in september 2025)
and you should be directed to the meta quest website) on a page similar to the part shown in figure 1 below.
Important point : PTVR works only if you connect your headset to your PC WITH A USB-C CABLE !
Figure 1
Click on the 'Download app' button.
And follow the instructions.
If you encounter problems, look for helpful information and assistance on the meta quest website).
If setup is correct, you should be able to see the following:
Figure 2
on your PC, in the 'Meta Horizon Link' application (previously called 'Meta Quest Link'), in the 'Devices' tab, you should see the screen shown in Figure 3:
Figure 3
Note 1: You can ignore the top message in the blue ribbon if you know that your computer is "VR Ready".
Note 2: You will need to buy a cable for connecting the headset to the PC click here for instance
For issues related to the connexion of the PC with the headset, explore the following:
In the 'Meta Quest Link' application (see Figure 3):
Clicking on the area containing the headset will open a vertical menu on the right (figure 4)
Figure 4
You can then scroll down the vertical menu, and click on different buttons. The 'Device setup' button for instance allows you to choose between a connexion with or without a cable (between the headset and the PC).
Scrolling down further within this vertical menu will reveal the "Graphics Preference" sub-menu (see figure 4 bis - middle right)
Figure 4bis
Clicking on "Graphics preference" will allow you to play around with the refresh frame rate (lower or higher than 90 HZ) and/or spatial resolution.
In the 'Meta Quest Link' application (on your PC) -> TAB 'Settings' -> TAB 'General' :
Activate 'Unkwnown sources' (see figure 5)
Figure 5 Note that the spatial layout of the different tabs and menus varies from one version of the meta app to the other.
Check that the message 'Meta Quest Link is set as the active OpenXR runtime' is displayed below 'OpenXR Runtime' (as in Figure 5). If not click on the button on the right of 'OpenXR Runtime'.
En français: Paramètres -> Général -> “Définir Meta Quest Link comme l’exécution OpenXR active”.
We recommend to do the following weird trick:
Once the above instructions in B/ section have been followed, setup should be finished and you should be in Science Fiction city (already shown in Figure 2).
Now, everytime you want to start a session of PTVR scripts, you should do the following:
Figure 7 : Point and click at "Quick settings" (to the left of the small toolbar)
The steps described above should lead you to a white room in your headset (Figure 8), indicating that you can now run your PTVR scripts to watch them in the headset.
Figure 8 White waiting room indicating that you can launch PTVR scripts to watch them in your headset.
When you quit your script, you will arrive again in the white waiting room, so that you can run another script again, and so on...
Summary
Once setup is finished, if you see the Science Fiction City (Figure 2), you will not be able to run a PTVR script in the headset.
To be able to watch a script in the headset, you will have to "go to the white waiting room" by following instructions provided just above (see Figure 7). And you can run PTVR scripts like this indefinitely if you do not quit the white room between two PTVR scripts.
Important Note (related to pointing):
As already said, once you're in the white room (Figure 7), all your scripts will run in your headset.
However, if a scripts makes use of handcontroller pointing, you will have to modify one line of code in your script to tell PTVR the name of your headset's manufacturer, namely "Vive" (for the HTC Vive pro series) or "Oculus" (for the quest 1, 2 or 3 metaquest).
This simple and single modification is described in the pointing section of the user manual (basics). If you forget to modify your code, do not worry, an error message will appear in your headset.
If you use an HTC Vive Pro headset AFTER having used the Quest, you might encounter problems. IN this case, try the following :
go in the Steam VR application -> Steam VR Settings -> OpenXR TAB and check that OpenXR is active.
